klungly
Sent from my SM-G950U using WAYALIFE mobile app
I'm more motivated since the ship pulled in. You'll have to come over more often. Once I start wiring it I could really use your help.Keep trucking. I was super jealous seeing it in person the other night.
Thank you, cant wait for it to be finished.So far, so awesome...
Thanks, i still get excited looking at it.
Finally got a contact patch I'm happy with and still kept backlash in tolerance. View attachment 287248 now to press on the new bearings and set pinion bearing preload and torque the pinion nut. Happy to be almost done with the gears.
Didn't need to. New pinion is on the right. Yukon just made an eliminator into the pinion shaft
Didn't need to. New pinion is on the right. Yukon just made an eliminator into the pinion shaft.
Yeah, you still have to shim the yoke side of the bearing to get that sweet spot of right pinion nut torque and preload.Good design. So do you just tighten it down until the proper preload spec is obtained?
Thank you!Looks amazing can’t wait to see how it turns out. :thumb:
