What was done to your rig this week?
Home depot brackets for redneck fabbing... paired with the ARB single brushless and the wayolife bracket. The extra body panel studs and empty mounting holes came in handy. The metal bracket holding the radiator overflow was a great grounding point for the compressor since it has 18-24 inches of the grounding wire...
I broke 7 of the 10 fender clips. After putting everything back together, I have 2 of the fender screws and I have zero clue where they go.
And after all that, the pressure switch stop working and the compressor won't stop and the safety valve is opened. But when filling a tire, it closes. So order a new one and more clips.
