Installing a PR44
Like every one else here has said, if you haven't set up gears before go get those installed by a professional, Then I would do the rest of the swap myself.
I didn't realize you were going to do the gears yourself. That's a whole nother beast. Specialty tools, a press, and some knowledge/experience. If you really want to do it yourself, there are youtube videos on it, but it's something you want to make sure that you have 100% correct.
I think I will go that route. All of you guys are awesome. I really appreciate all your help!
When you order the axle all the internals should come installed from Dynatrac (minus axle shafts) unless the shop is a certified installer from them. If they are they should install all of them at no extra charge. When the internals are done the axle itself is a direct bolt in. It took me and a previous friend about 7 hours to swap my d30 out, install the shafts, swap over the knuckles, and bolt everything back back up.
"Previous friend"?
