atrollip
After installing the Evo coils in front i noticed that the right hand side(our driver side) the coil was rubbing against new swaybar link. The swaybar links seem to be within 5° of horizon. They are BDS quick disconnects for 2-4" lift and they were set to shortest length(8.6") which measured exactly the same length as OEM back sway bar links which is what is normally recommended for the levelling kit in front. After installation the coil also seems to be slightly angled. Last night I took of tyre just to check whether swaybar link really was rubbing coil as it was driven to work and back yesterday. It definitely was rubbing.
Something else i noticed was that swaybar link was not installing at a near vertical position but was quite slanted toward the inside of the Jeep.
Any advice on how to resolve this or what to look at will be appreciated.
