Otzy
Hey guys,
so im planning my build on my 2009 2 door jk sahara, and i wanted to run over some ideas and thoughts with you guys to clear up my questions and plans.
So i decided to go with 35s for now because i don't have money for a new axle and the re gearing etc and don't even need 37s for anything other than looks at this point. however with that said i want the option to upgrade to 37s without redoing my whole suspension and buying a new lift kit. so i plan on going with a 4" suspension lift and 35s. would putting my body that extra inch higher above the wheels effect the drive and is anyone currently running 4"s with 35s? how is it?
im thinking of either going with a TeraFlex 4" Suspension System With (8) Full FlexArm, With 9550 Shocks, or with the evo mfg 4" Lift Kit ENFORCER Package w/ king shocks. both would come out to around 2400.
does anyone have a preference or tested reviews of either kit? and which would you go with yourselves?
after putting in the new lift ill probably add a coast jk 1310 drive shaft, and then some c gussets to my dana 33 just for added security. would you guys recommend regearing for 35" tires or no?
and then on that ill throw on some 35 inch toyo m/ts or a/ts, not sure which ones i want yet though, a/ts sound nicer for the snow out in colorado, but i haven't found anyone who runs them yet.
thanks for any advice which yall can give me on the build. am i missing anything crucial for the survivability of my vehicle on 4"? and what would you guys do differently.
