Where can i get my C Gussets welded on? NJ
If you can do most of the prep work, you might want to look into calling a mobile welder to burn it in.
I would look into eddies suggestion first. If not then try Globex performance in toms river. They did my gears and I'm sure they would weld the gussets on for you. The first route is deff the cheapest
Sent from my iPhone
