TerraJL
Hey all!
I watched Eddie's video on performing the Synergy ebrake relocation bracket install. Thanks for making that video, Eddie. Very helpful!
I have 2 questions:
First, when you reroute these cables, I noticed that they are pressing against the evap vapor tube. It's not a lot of pressure but they are definitely resting on it. Is that going to be a problem? I noticed Eddie also routed the cables under it so they are resting on the tube.
Second, the cables also now rest on the rear differential. Is that going to be an issue over time with rubbing and heat?
Thanks in advance,
TerraJL
I have 2 questions:
Thanks in advance,
TerraJL
