Stabilitrak
Deankxf
So I just got the jeep aligned today, everything’s right on, steering wheel is perfectly straight, but stabilitrak still keeps applying brakes to the front end on turns, anything else causing this?
the stability control system sees one wheel spinning faster than the other and will apply the brakes assuming you are in some sort of slide.
once you change from the OEM tire size it affects it.
Make sure both tires are at the same tire pressure but better yet, disable the Stability control, you'll get a ESP warning at start up and a light on the dash but it'd better than having the system decide when it wants to apply the brakes.
If you have a Rubicon you should have a ESP switch to temporarily disable it, it'll reset each time you shut down.
Alternatively you can take it to the dealer to flash the ECU and disable it or do the steering wheel dance to permanently disable it.
Larger tires should have no affect on the system. I'd check the connections and wires at each sensor to make sure they're tight and not frayed or damaged.
If they're good, then one of the sensors is probably bad. Buy one and swap out one at a time until you find the culprit or replace all 4.
There's probably a way to test the sensors with a meter, but I don't know what the readings are supposed to be.
Build Thread - Adventures of Fiona - https://wayalife.com/showthread.php?t=47407
I am having to same issue. I recently replaced both my unit bearings up front, so both front sensors are new. I began looking into the rear couple weeks ago, I started by cleaning the tone rings
Before
After
That didn’t fix it.
I ordered new sensors for the rear ($20 each), so far changed the rear drivers side. Still doing it, I know I have slightly bent shaft on that side as well. With closer inspection of the sensor I can see that the tone ring is making contact with the sensor itself. I wonder if that’s the cause of the abs engaging.
Here’s a shot of the sensor I took out on the side with a bent shaft
I still need to replace the rear passenger side sensor to see if that will fix it. Hopefully someone with more experience will chime in on this issue.
Did you happen to disconnect the steering shaft or pitman arm? I'm wondering if the steering wheel is 360 degrees out of sync.
That can't happen. The sector shaft only has three teeth and won't move out of sync.
If you installed it wrong you'd know as you'd have no steering to one side.
Right. The only way it would happen is if the steering shaft had been disconnected from the gear box and spun before being reattached.
Sent from my Pixel 2 using WAYALIFE mobile app
Bad speed sensor will do this as would a speed sensor cable that's chaffed and grounding out as it makes contact with something metal on turns.
How can I disable it?
I would hope they are good, my jeeps a 2017 with 4,xxx miles
