Need some help
Miles4k
Hey guys, my question is "could really high tire pressure cause a little bit if wobble in the wheels when I'm driving?" Like the steering wheel is kinda spinning back and forth about 3 inches... And I just put on a steering stabilizer
It's not a urgent matter but I would like some help
Thanks
Thanks
I guess it could. What kind of tire pressure are you running? Typically that is a sign of play in your steering box or really low caster angle.
Well it was 60 (a shop put up to that and I forgot to check it) and I lowered it down to about 35
Every once in a while
Not as much... Mybe 1or 2 times a week now, apose to 5 or 6 times a week
If it's not all the time, then probably not a tire pressure issue nor a caster angle issue. Sounds like you may have a loose part, that would be my best guess.
too high a pressure will give you a floaty almost too easy to steer feeling, had the same thing on mine when they put the PSC hydro on. tire pressure was maxed out.
