ldjernes
Ok this is me having lack of experience because I'm still new to this but I need some help/advice. My jeep was in a wreck last November and we are slowly rebuilding it. I have been working on the front end adding an evo drag link flip kit and new shocks and so forth well I noticed that my sway bar disconnect was closer to my passenger side spring then it was on the drivers side so my dad and I took a measurement from the first body mount bolt on the jeep to the grease zirk on the upper ball joint and there is a half inch difference from the passanger to the drivers side. I'm assuming the control arms need adjusted , was curious to see how you guys measure or go about to make sure your axle is straight and not sitting on an angle any advice will be much appreciated thanks.
