My stupidity
Deankxf
Well today I put my jk over a hillside, only reason I’m posting is because I slammed my front axle (Dana 30) into a stump on the passenger side wheel, what all should I look into so see if I have any damage, seems to drive and steer fine just want to be safe, thanks in advanceIMG_1121.jpgIMG_1124.jpg
Well today I put my jk over a hillside, only reason I’m posting is because I slammed my front axle (Dana 30) into a stump on the passenger side wheel, what all should I look into so see if I have any damage, seems to drive and steer fine just want to be safe, thanks in advanceView attachment 292451View attachment 292452
Kick the tire a couple of times.. did it fall off? No? You're probably good.
Sent from my ONEPLUS A3000 using WAYALIFE mobile app
fi you checked your tie rod, draglink and they are not bent, next things that might be damaged would be control arms, hub or knuckle.
But since it drives straight and no shake, you're probably ok and no damage.
Snow cushion for the win!
You may want to keep an eye on the diff fluid level or looks for signs of a leak from the axel tubes. I did something similar many years back and thought everything was fine, as it seemed to drive fine and no obvious damage. But turns out I had bent the housing a little and it caused the seal to fail and dump out most of my diff oil. Although you are probably fine its just a thought from my previous mishap.
