Phase 1.1 Body Modifications
After I scored the Metric Ton D44 rear axle assembly that would eventually replace the stock D35, I had to think about what aftermarket accessories should be ordered and what other body modifications were needed before re-painting the Comanche.
From various Internet postings and conversations with people who had done similar swaps, we thought that doing a Spring Over Axle (SOA) modification when the rear axles were swapped, would result in about a 6" lift even if we kept the tired 1/2 ton stock leaf springs. I didn't want to lift it any higher than 6" and I wanted to keep a decent ride, so we decided to keep the old springs and upgrade them to something like similarly sized S10 springs only if necessary. After all, we were going to the D44 to get away from the stock D35, not to increase our load capacity and we could do the SOA lift with just about any axle assembly. Even with a future 6" lift planned for phase III to clear 33" tires, we decided to trim the lower rear sheet metal of the bed for additional departure angle clearance. If I had to do it over again, I should have held off and bought a short bed Comanche to begin with, but even then I probably still would have trimmed the rear sheet metal.
Let the Mods Begin
I had won a set of OR-Fab tube doors for my JKU from a contest on JK-Forum, so I had a soft spot for their products and decided to order their JEEP CHEROKEE XJ 3-PIECE FRONT WINCH BUMPER which should clear 33" tires, but still required the front fenders to be cut. For the most part, everything on the MJ/Comanche in front of the bed is based on the XJ/Cherokee. The OR-Fab front bumper I ordered also included a frame stiffener for the steering box, which seems to be a common point of failure when wheeling MJ/XJs.
Several of the fields at our tree farm can only be accessed by fording creeks that run through the property. While all the creeks flow year around, depending on the season, some of them can run several feet deep or more, so a snorkel seemed like a good idea and I ordered an ARB Safari Snorkel kit for a XJ. This kit needs a rather large hole drilled through the left front fender and some modifications to the stock air box. In the picture below, we are test fitting the OR-Fab bumper and have trimmed the forward edge of the front fender and cut the hole for the snorkel. The second picture shows where the ducting for the snorkel enters the air box.
About the time I started ordering these upgrades, Hanson announced their plans to produce a rear bumper for the MJ/Comanche. Because the rear of the Comanche is so different from the XJ/Cherokee, there are fewer products available from vendors. There was nothing wrong with my stock rear bumper, but I decided to pre-order the Hansen bumper even though I would not need it right away. As it turned out, delivery of the Hanson bumper took so long that it actually ended up delaying the build slightly.
