sldrstoy
Just an FYI that I'm sure most savvy JK owners know, but the Rubi's and I'm sure a few other models come with a heat shield on the hood that interferes with the fitment of the compressor. Not a big deal if you don't mind the compressor and/or hose fittings cutting into the heat shield. I used the Barnes4x4 mount because it was suppose to be easy to install.... A day later and a lot of cutting I was able to drop the compressor low enough to clear most things... Not a knock at the part just an FYI.
Hopefully the picks works, but I ended up dropping the mount down quite a bit and shouldn't have as many parts cutting into the heat liner anymore. [emoji482]
