Im going to offer a package deal with the bracket extensions and the bulb gasket. The brackets are used to move the light bar forward about 2 inches to eliminate the soft top flapping. The gasket is used to eliminate about 90% of the whistle from the light bar. Any whistle you might hear after the gasket is wind coming in on the sides of the light bar. To eliminate this you will need to put silicone in the ends. I can also sell one item or the other if you would like. Brackets can be customized as well if needed. Below are the package deal items.
$25-(2) metal brackets 1/4" thick with 3/8" dia. holes for mounting (Hole sizes can be changed)
$25-(3) strips of bulb gasket at 48" long (length can be modified)
