Jeep Gladiator electrical gremlins
mtudb24
Long story short. Bought a new gladiator in Oct 2020 as a 2021 model year. Oct 2024 my "avenger" light came on. In November, the truck died in my driveway at 8V and I bypassed the aux battery by pulling the negative battery cable and fuse 42. Was happy to get 4+ years out of aux battery.
All's well. Then in Jan 2025, my voltage gauge on my cluster went to 16V and all lights on the cluster came on. Traction control, service stability, park brake, abs etc. My main battery was shot. Replaced with a new group 94 battery.
Fast forward to now at 7 months later. I get the same messages on my cluster of traction control / brake system / abs after driving for a bit. Voltage at idle drops to 11 plus and while running goes over 15.3V.
I pulled my battery and used a AGM battery charger and it was 77%. Took about 1.5 hours and it was at 100%. Started driving home from the cottage tonight and about a hour into the drive, the same thing happened. Traction control / service ABS lights came one when my charging voltage on my cluster went to 15.3+Volts.
Got home and put a volt meter on the battery with the cables connected and disconnected and it was 12.7V but my cluster showed 10.9V. Truck wouldn't remote start ( pushed the remote start button and it would beep once but wouldn't start), but started right up when using the push button.
Why in the world would my battery show 12.7+ volts with and without the battery cables connected but my dash voltage would show 10.9Volts?
Gonna take the battery to the shop I bought it from for a load test but I can't imagine its bad if it shows 12.7V.
Could this be a bad IBS sensor or bad alternator or ????
Thanks for any advice.
Todd
Todd
A bad cell within the battery will show good voltage when it’s stable and be all over the place when it’s running.
Todd
In addition to what cozdude says, keep in mind that battery testers in the store primarily test discharge rates under load similar to starting. They may not detect issues which occur during normal operation.
Have you tried a new battery(ies) yet?
Yes, put a new Group 94 battery about 6 months ago. I "isolated" and took the aux battery out of the equation by removing the negative cable and pulling fuse 42. Gonna try and get the new main battery load tested tomorrow to see if that's the issue.
All grounds checked. Battery passed the load test but when we put the alternator test tool on the truck, the tester kept saying the voltage regulator failed.
I'm wonder if this is actually a alternator issue? I know the PCM / BCM / IBS control all that voltage stuff.
I Honestly quit. Time to start a new project.
Went out to the truck today, remote start worked, blower motor worked, headlights didn't flicker and the voltage never fell under 13.2V at idle to 14.2/3 while at 1000rpm or at 3000rpm and no warning lights on the dash. Its like nothing ever happened. WTF???? If your broke, stay broke so I can fix you vs trying to chase a Ghost.
For you Seinfeld fans, I'm just gonna drive it about 35 mins south to 8 mile and leave the keys in and walk away, so have at it!!!! At least you won't have the "Beast" smell to deal with 😎 :) 😎 :)
Might wanna remove that link…
