darkknight1999
So I picked up my Jeep a few months ago... I had an Escalade before... which is a very nice 400hp couch on wheels, but as we know not nearly as fun as a Jeep. So the Caddy is gone and fun is in! The Jeep is a 2007 Rubicon Unlimited.
I have along list of parts I want to get... but with a family (Wife Patty, 2 daughters (Hannah 16, and Maddy 10) and 2 dogs) oh and I own my own company. So I'm a pretty busy guy...
Here is a list of parts... Its a work in progress and some of the parts listed could change:
Bolded items are installed or ordered
All fluids are AMSOIL
Engine Oil (Filter) • Absolute Efficiency Oil Filter (EA15K51-EA)
Engine Oil (fluid) • Synthetic 5W20 SS Motor Oil (ALM1G-EA )
Transmission (fluid) • Synthetic 5W30 Manual Trans (MTFQT-EA)
Engine (flush) • Engine & Transmission Flush (FLSHCN-EA)
Diff/Gear (fluid) • Synthetic 75W110 Gear Lube (SVTQT-EA)
Transfer Case (fluid) • Synthetic Multi-Vehicle SS ATF (ATFQT-EA)
Fuel Additive (Injector Cleaner) • ORMD Quick Shot Fuel Additive (AQSCN-EA)
Brakes (fluid) • Amsoil Series 600 DOT 4 Racing Brake Fluid (BF4SN-EA)
Brakes (front rotors) • Power Stop Dimpled/Slotted Sport Rotors
Brakes (front pads) • Power Stop K2798 Front Ceramic Brake Pad
Brakes (rear rotors) • Power Stop Dimpled/Slotted Sport Rotors
Brakes (rear pads) • Power Stop K2798 Rear Ceramic Brake Pad
Brakes (SS Lines) • Toxic Offroad Custom DOT Approved Braided Stainless Steel Brake Lines (TXCJPJK104)
Wheels • Temporary - Pro Comp Alloys 7069 Flat Black Wheel (16x8"/5x5") - When funds are available Hutchinson Rock Monster™ 17"x8.5" Wheel, in Argent
Tires • Mickey Thompson LT315/75R16 Baja MTZ (90000001479)
Rock Sliders • ACE Engineering JK Rock Sliders (4 Door)
Front bumper • ACE Engineering JK Pro Series Front Bumper (10" LED light bar provision) (Bull Bar)
Rear bumper • ACE Engineering JK Pro Series Rear Bumper with Tire Carrier (dual 6" LED light bar provisions)
Programming • Superchips 3570 FlashCal for Jeep Wrangler JK
Winch • Superwinch Tiger Shark 9.5, 12 VDC winch
Gear upgrade • Yukon (YGK015) Gear and Install Kit for Jeep JK Rubicon Differential
Diff covers (Front) • Poison Spyder Bombshell Diff Cover - Dana 44
Diff covers (Front) • Lube Locker Dana 44 Differential Cover Gasket
Diff covers (Rear) • Poison Spyder Bombshell Diff Cover - Dana 44
Diff covers (Rear) • Lube Locker Dana 44 Differential Cover Gasket
Under Carriage armor (Front) • Rock Hard 4x4 RH-6003 Oil Pan Transmission And Dual Catalytic Converter Skid Plate
Under Carriage armor (Transfercase) • Rock Hard 4x4 RH-6004 Transfer Case Skid Plate
Under Carriage armor (Gas Tank) • Rock Hard 4x4 RH-6001 Gas Tank Skid Plate
Under Carriage armor (Evaporator) • Rock Hard 4x4 RH-6005 EVAP Canister Skid Plate
Suspension (Lift Kit) • Fortec® 2.5” Suspension Kit by Rubicon Express with Bilstein 5100 Shocks
Suspension • FORTEC® Exclusive Bilstein Dual Steering Stabilizer Kit
Suspension • Synergy Chromoly Tie Rod
Suspension • Synergy High Steer Drag Link
Suspension • Synergy Front Track Bar
Suspension • Synergy D30 Heavy Duty Front Ball Joint Set for
Suspension • Synergy Front D30 Inner C Gusset Kit
Suspension • Synergy Rear Track Bar
Front Fenders • Smittybilt 76880 Jeep Wrangler XRC Armor Front Fenders
Rear Fenders • Smittybilt 76882 XRC Textured Black Armor Rear Corner Guards
Radio Deck • Alpine CDE-147BT Receiver
Speakers (Dash) • (Temporary Alpine Type-E Series SXE-1750S) Focal Access 165 A3 - 6.5-Inch 3-Way Component Speaker Kit
Speakers (Soundbar) • (Temporary Alpine Type-E Series SXE-1725S) Focal Access 165A1 - 6.5" 2 Way Component Speakers
Subwoofer • Focal 5" 180W K2 Power Subwoofer 13KS / 5K4441 - x2
Amplifier • Alpine PDX-5M 5-Ch Digital Marine Amplifier
CB radio • Uniden BEARCAT CB Radio With Sideband And WeatherBand (980SSB)
CB radio antenna • Firestick II 4 feet Tunable Tip - Black
CB radio antenna mount •*Custom
CB radio antenna coax cable • 18' RG-58A/U Coaxial Cable With Pl-259 Connectors
Optima Blue Top Battery
Lighting (Head Lights) • GE 7" Round Nighthawk LED
Lighting (Aux front lights, bumper) • Lifetime LED 10" Light Bar Front Bumper
Lighting (Aux rear lights, bumper) • Lifetime LED 6" Light Bar Rear Bumper (Dual)
Lighting (Aux front lights, Windshield) • KC 6" HALOGEN
Lighting (Aux Roof light) • CREE 50" LED 288w Light Bar LED Spot Flood Combo
Lighting (Aux front lights, Windshield) • CREE 2x4 LED
Lighting (Aux rock lighting) • LED lighting strips custom installed
Air intake • Rugged Ridge Modular XHD Snorkel Kit
Exhaust (cat back) • MBRP Black Series Cat Back Exhaust System
High lift jack • Hi-Lift Jack X-Treme Jack 48"
Dominion Offroad • Hi-lift Jack mount
Hood Vent • Posion Spyder
Custom 6-pack mold switch pod
Lots of custom wiring and molding... I love to design and build stuff. I'm a telecommunications network cabling infrastructure engineer/electrician/car audio designer/customizer.../macgyver... lol I'm a big fan of do it right the first time or don't touch it. :thumb:
So after I picked up the Jeep the first thing I needed to do is find a place to mount my iPhone. I use my phone for everything... Personal, work, GPS, maps/topo, etc. I have a magnet mount in all my other cars... but the Jeep needs a more secure mount; so when we're out in the woods it can't fall off.
This is what I came up with... the design might change as time goes on but for now this is it:
I made my own bracket out of aluminum and use a Rokform case and mount. Works perfect... Only took about 2 hours to make.
I made the bracket out of scrap aluminum I had (cut and shaped the aluminum with a Dremel). Once I had the basic shape I bent it to match the contour of the dash. I painted and textured it to match the dash. I picked up the allen bolts and washers at the hardware store for $4 bucks.
Once it was ready I mounted the Rokform mount to the bracket. Then I riveted the bracket to the dash. The Jeep could roll over and its not coming off
This is the case I use.
iPhone 5/5s Case with Bonus Car Mount | Rokform
If anyway has any questions just let me know.
