That shit is a waste of money. Your trying to wring hp out of a minivan motor. You want better power - do an engine swap.
Exactly.....
I guess I missed the part about a $10-15k budget
Seriously though, you could get a Viper throttle body for $100 all day. That and an intake to match woke mine up quite a bit.
Without the tb, i want impressed with the cai. Mine was cheap as hell or I wouldn't have been running it. For the $45 I had in it, I guess it was worth it.
I have a 2011 4 door rubicon with the 3.8l and am looking for any advise on cold air intakes and throttle body spacers ! Are they worth the money when it comes to hp and gas mileage gains every little bit helps with the 3.8l ? Any advise and experience is appreciated!
Without the tb, i want impressed with the cai. Mine was cheap as hell or I wo<script id="gpt-impl-0.4222293619332402" src="http://partner.googleadservices.com/gpt/pubads_impl_81.js"></script>uldn't have been running it. For the $45 I had in it, I guess it was worth it.
OP with the Viper TB, how did you get past the ECU trying to adjust to the Viper TB? what intake did you put on? Do you have any real gains? I've looked into trying this but from the info I've received, the gains are no more than a CAI only the CAI is less hassle.
I've seen several of my friends try the Viper TB swap and each one was a failure, the ECU would never adjust
If you were to throw the Jeep on the dyno before and after any mod or swap, you MAY see performance gains, and at the pump, you MAY see gains as well. With that being said, there are so many other factors that can result in good or bad readings. I've had good luck with CAIs over the years but when it comes to Jeeping, I really don't give a shit. I didn't buy my Jeep for the race track nor to save gas.
