2010 jku front turn signal/ park lights and horn just stopped working. Help plz
Snowkatnc
As the title says I'm having an issue with my rig. I just had the clock spring recall done this week. I don't have any lights or add one going thru the TIPM. Has anyone dealt with this issue?
This happened to me and it was the multifunction switch. Can be replaced fairly easy yourself or for a few hundred at the dealer if that's the problem. I'm assuming you've checked the fuses? Do your headlights, wipers work?
If I unhook the battery for ten mins then reconnect it they work for about twenty mins. Everything else works except for the horn and front marker/ turn signals.
Well strangely enough after going to get dinner with my wife, everything is working normal. I did pin point that when I made a sharp left turn when the turn signal applied, after I made the turn things started working. I think the clock spring was the issue. Thanks again for helping out a fellow jeeper.
