WJCO
Meme King
AI Bot for sure.Oh I’m aware. It’s common knowledge I thought. Hence my comment. He says stuff nobody asks or wonder or questioned.
It’s normal practice in red states. People burn pastures and forests all the time clean the underbrush and make better habitats for wildlife.My dad has told me that, in at least California, the Native Americans would set fires in the forest. Because there wasn’t dozens of years of wind fall and slash lying all over, the fires would rush through snd clean the understory and never harm the trees since the fires weren’t that hot. Don’t know if it’s true or how they knew how to do that; haven’t researched it.
The huge fires on the north rim of the Grand Canyon 1/5 of forested area burned already) have given the forestry department the heebie-jeebies. The fire which burned the Grand Canyon Lodge was being used like a controlled burn.Mismanagement by the forest service is a big part of the problem. Bob somehow makes sense here a series of smaller fires would have been preferable to the large uncontrolled fires you’re seeing now.
How the Great Fire of 1910 Changed How the US Fought Wildfires | HISTORY
When a historic fire roared over more than 3 million acres in Montana, Idaho and Washington, the US Forest Service ca...www.history.com
This really hurts my ego given that I hold you in such high esteem.Sometimes I wonder if you are a mediocre troll or just have one fucked up brain.
I have heard the same. Since I am now old, I can see that the forests are not like when I was young. When I was young, you could just walk through most of the forest, but now it is often impenetrable brush, or young trees so close together you can almost not stick your arm between them.My dad has told me that, in at least California, the Native Americans would set fires in the forest. Because there wasn’t dozens of years of wind fall and slash lying all over, the fires would rush through snd clean the understory and never harm the trees since the fires weren’t that hot. Don’t know if it’s true or how they knew how to do that; haven’t researched it.
I agree about the forest…I have heard the same. Since I am now old, I can see that the forests are not like when I was young. When I was young, you could just walk through most of the forest, but now it is often impenetrable brush, or young trees so close together you can almost not stick your arm between them.
To me this problem is even worse than the SxS tearing things up.
In Canada.You should try it again. Now. Go for a long one.
It may be some days before Burning Man is added.
